Start a program after defragmentation is finished
Running another program, after defragmentation is finished, may be useful in the sample case (useful for developers):
1) Before defragmentation all temporary files (which are generated during compilation ~10 GB) are removed.
2) After Defraggler succeeds, the compiler is run to build the sources.
I suppose a script can be written to manage this scenario, but I don't know how to tell Defraggler to quit after it finishes (some sort of command line option may help).
Your question seems confusing a bit.
I believe you want Defraggler to:
- Run a program before defragging (so you can delete certain files)
- Defrag
- Run a program after defragging
I think this will make it simpler to understand.
