stand by stuck
hello everyone, for some weird reason my xp pro started to acting strange. when it times for stand by it just stay there,i don't think it is freezing because i pressed the number lock key and it still work. (it did change to the stand by screen though, just stay there .any help would be appreciated?
Any help at the link bekow?
Kelly's stanby issues
first,set my stand by less then 45 minutes so i don't know if it would works with the instructions. secondly, the links to download the hotfix does not works,but thnks
.... i don't think it is freezing because i pressed the number lock key and it still work.
The Num Lock / Caps Lock keys are low-level operations and never (appear) to be affected by windows-crashes / locks etc.
They will 'almost' always work (for some reason - I have no clue why; maybe Dos related ...another topic)
If they do appear to work there is a slight possiblity that windows will come back to life (usually highly unlikely) - if, however, said buttons refuse to work at all ....then u may as well power-off (ideally you will have XP and above !)
