84 new items :
IE : 82 items
Restricted Sites : 2 items
Total Database on 25/02/09 : 12148
http://www.javacoolsoftware.com/sbdownload_setup.html
cheers
84 new items :
IE : 82 items
cheers
Spyware Blaster Update!
Spyware Blaster 4.2 is out! Download link from FileHippo: Clicky!
New in this version:
-Windows 7 support
-Internet Explorer 8 support
-K-Meleon support
-Faster, secure updating worldwide
-Automatic program version upgrade support (for AutoUpdate users)
-Numerous bug fixes, tweaks, and optimizations
Hmm it seems "FilePig" has the change log but FileHippo doesn't. Are these 2 sister sites or is "FilePig" a rogue site?
Keith
Looks like they're just a (fairly blatant) copycat site:
http://filepig.org/forum/index.php?PHPSESS...opicseen#msg671
16 new Items added > 13/04/09
12299 Items in Database.
still can't access their site in FF3 ! take a look below :
any ideas ?
Not sure but it's working fine on my end with the 3.1 beta.
Maybe is all those add-on's you've got, that screenshot makes me mentally scream in pain lol.
abu can you access here?
FF3 & Opera not worked
Chrome , Maxthon & IE8 fine
Here is screenshots
No idea which one but try disabling them all (not removing) and test, if it fixes it enable them one by one.
If 3.x is the reason, try uninstalling then installing a previous version and test again.
I tested my copy of FF 3.0.8 (non beta) and it still loads fine for me.
<edit>
I've seen a few posts in google about trying this:
1. Try clearing your cookies and your cache
2. Type about:config into the URL bar, list of configuration settings for Firefox
3. Locate the setting for 'network.automatic-ntlm-auth.trusted-uris'
4. Set the value of names of the servers to use NTLM with.
5. Locate the setting for 'network.negotiate-auth.trusted-uris'
6. Set the value of names of the servers to use NTLM with.
7. network.automatic-ntlm-auth.allow-proxies = True
8. Restart Firefox - Test URL to again
<edit2>
seems another user had similar issues with a different site but no resolution:
Nope what you said was exactly (almost) what I was thinking. So I just decided to quote you.
So the most pointless post of the year goes to...
Nice one Icedrake
Updated 27/04/09
40 new items added > 12338 in database
updated 13/05/09
68 items added
12406 in database
Thanks again Abu!
Thanks and now in my Favorites.I keep having to learn how to spell things without a "u".
My next challenge is getting IE7Pro working as it crashes IE for me and had to use System Restore to go back to before its installation.
Good grief!
Everything is so hard to find now.
I have my APC Battery Backup working fine as I found a Vista version that works well.
Is GIMP2 better than Paint.NET?
It is one of the pre-installed applications that I am totally unfamiliar with such as CyberLink DVD Suite, Corel Snapfire, Click&Clean, LiteScribe and Nero SmartStart Essentials.
I believe Cyberlink DVD Suite is just a dvd player application. I think my school laptop came with it. Maybe the "suite" version is a lot more complicated, otherwise it's just a full screen window with "eject, resume, restart movie, etc."
To screen capture, press Print Screen, then Ctrl+ V in Paint or any other picture editing program.
updated again ! 25/05/09
34 new items added (IE)
4 new items added (Restricted Sites)
12444 in database
Thanks Abu!
Going to Filehippo and Calender Of Updates every day kinda puts the kabash on that.
