SpywareBlaster uninstalling problem
I don't like that it leaves stuff behind like that.
I have many entries there without any values on them, like many bonzibuddy entries.
Well, they're harmless, and, as I said, they can safely be deleted.
I agree with you in that it would be preferable for SB to completely remove the subkeys themselves in case of an uninstall. Maybe a suggestion to post at Javacool's forum at Wilderssecurity?
http://www.wilderssecurity.com/forumdisplay.php?f=19
Why there's no values on those some entries, even though all protection is enabled? Are they still for protection and active?
Protection for a CLSID is "on" only when the "Compatibility Flags" DWORD value is present in the subkey in question, and its value data equal "0x00000400"
No idea why you should have 'empty' keys there once all protection is ENabled, unless a number of CLSIDs were removed from the SpywareBlaster daatabase in previous updates.
Note, SpywareBlaster is not the only software writing to that registry key. SpyBot does as well ("immunisation") , and there are others, so it's probably a little rash to accuse' SB of having put them there.
It's possible, that those empty entries are created by SpyBot, since i have SpyBot. Although i don't remember enabling the immunize option. I guess it's still possible, that i have enabled it in some state. I have had it for so long time and few versions, i don't have the latest though.
If this bothers you, yes, you can remove the entire "ActiveX Compatibility" subkey, then recreate an empty one afterwards
Is it really safe to do so, since there's some Windows created entries too?
To remain on the completely safe side, it IS probably best to remove only those subkeys that do not contain the Compatibility Flags value; although that would be a time consuming business.
But again, it can't hurt to leave it alone entirely, as the 'orphaned' registry keys are harmless, and do not really contribute much to 'registry bloat'.
There should be a program to remove empty/unused entries from 'ActiveX Compatibility' key.
