I was under the impression we were talking about installing either 3.5 or 3.5.1 over top of 3.4, in which case, I believe you should turn off the protection and uninstall 3.4 first. If you are going from 3.5 to 3.5.1, Javacool says this is not necessary.
I installed 3.5 over 3.4 and worked fine while others had problems and then installed 3.5.1 over 3.5 without turnningoff any protection even custom blocking remain. Am I suppose to uninstall first and WHY. Thanks
To the best of my understanding, items have to be turned off and uninstalled because the running components are the ones that have to be updated. This is the same reason that a lot of installers ask you to close all other programs before running them. If a component that has to be reinstalled or updated is still running, obviously it cannot be changed until it is stopped or removed.
So, when it comes to SpywareBlaster, the components run in the background. These are the components that have to be updated, so of course they must be stopped first. As far as the uninstallation goes, I don't know if that is necessary, but it certainly can't hurt.
Evidently the newest versions of SpywareBlaster stop their own running processes automatically, so that you don't have to do it manually every time you update. It's one of those things were you go, "why didn't they come up with this sooner?"
