Spybot S&D problem?
Spybot S&D is showing these as being a problem, (see below image).
Should I ignore them or fix them?
Incidentally, image created using Snippy.exe, which I discovered on Dj's site, what a great little program. :)
I've seen that before on comps that were infected with malware and fixed it every time.
Got that today, except it was under the heading 'Security Risks'. Right now, I'm not certain this is a specific malware causing this, because recent Norton products "don't share" status with other programs/take over the Windows firewall settings, and I believe those are the settings being found.
http://forums.net-integration.net/index.php?showtopic=32257
Thanks everyone, I will just ignore it.
Recently, I got it every time I scanned with spybot. First time I deleted it, but comes back again. So now, I just ignore it.
Cheers
So what's the verdict another false positive?
