I just updated to SypBot S&D 1.51 and CCleaner no longer lists SpyBot SD in the Aplicattions for cleaning. Is their a way to correct it?
I found that the entry in the winapp.ini for spybot 1.4 was the following:
[spyBot Search and Destroy]
LangSecRef=3024
Detect=HKCU\Software\PepiMK Software\SpybotSnD
Default=True
FileKey1=%allusersprofile%\Application Data\Spybot - Search & Destroy\Logs|*.*
FileKey2=%ProgramFiles%\Spybot - Search & Destroy|advdebug.txt
FileKey3=%allusersprofile%\Application Data\Spybot - Search & Destroy|Statistics.ini
FileKey4=%windir%\All Users\Application Data\Spybot - Search & Destroy\Logs|*.*
FileKey5=%windir%\All Users\Application Data\Spybot - Search & Destroy|Statistics.ini
The new verions of spybot S&D is listed in the registry as:
LangSecRef=3024
Detect=HKCU\Software\Safer Networking limited\SpybotSnD
Default=True
The lines in red show the old dectect entry and the new one I entered.
I copied the entry from the winapp.ini and made winapp2.ini with the same entries and then changed the detection listed above and it show up again in CCleaner, but I am not sure of the other entries and don't want to use it until someone can confirm that I have entered it right.
Thanks for any help,
Normandie
