Had a google around but all I could find was something similar but with a different .vbs command.
Don?t forget to defrag your Ram every now and then when you?re on a PC. You can use a Visual Basic command to do so: all you need to do is create a text file on your desktop. Call it something like "Defrag Ram". Write:
FreeMem=500000000
and save as Defrag Ram.vbs
In this case you would recover 500 Mb ram (500000000) - never write a higher number than half your physical Ram. All you have to do from now on to defrag the ram is doubleclick the Defrag Ram.vbs file on the desktop.It might take a while to defrag (a couple of seconds)- don?t do anything till it?s done. A quick and easy way to get some Ram back .
open notepad and save it as a .reg file ( the name could be anything with a .reg extention)
this is what u type in notepad and save as name.reg
Windows Registry Editor Version 5.00[HKEY_LOCAL_MACHINE\SOFTWARE\Classes\CLSID\{87D62D94-71B3-4b9a-9489-5FE6850DC73E}\InProcServer32]@=hex(2):00[HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers\Copy To]@="{C2FBB630-2971-11D1-A18C-00C04FD75D13}"[HKEY_CLASSES_ROOT\AllFilesystemObjects\shellex\ContextMenuHandlers\Move To]@="{C2FBB631-2971-11D1-A18C-00C04FD75D13}"[HKEY_CLASSES_ROOT\Directory\Shell\DosHere]@="Command &Prompt Here"[HKEY_CLASSES_ROOT\Directory\Shell\DosHere\Command]@="%windir%\\System32\\cmd.exe /k cd \"%1\""[HKEY_CLASSES_ROOT\Drive\Shell\DosHere]@="Command &Prompt Here"[HKEY_CLASSES_ROOT\Drive\Shell\DosHere\Command]@="%windir%\\System32\\cmd.exe /k cd \"%1\""[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer]"Link"=hex:00,00,00,00[HKEY_CURRENT_USER\Software\Microsoft\Notepad]"StatusBar"=dword:00000001[HKEY_CURRENT_USER\Software\Microsoft\Notepad]"fWrap"=dword:00000001[HKEY_CURRENT_USER\Control Panel\Desktop]"AutoEndTasks"="1""HungAppTimeout"="1000""MenuShowDelay"="8""WaitToKillAppTimeout"="2000""LowLevelHooksTimeout"="1000"[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]"NoLowDiskSpaceChecks"=dword:00000001"ClearRecentDocsOnExit"=dword:00000001"NoRecentDocsHistory"=hex:01,00,00,00"LinkResolveIgnoreLinkInfo"=dword:00000001"NoResolveSearch"=dword:00000001"NoResolveTrack"=dword:00000001"NoInternetOpenWith"=dword:00000001[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control]"WaitToKillServiceTimeout"="2000"[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\RemoteComputer]
after u save it .. open the file u just saved .. it will hopefully make ur computer faster maybe after a reboot ?
Interesting comment in the discussion under the video:
Creating a small Visual Basic script to set mystring=(800000) will actually take up a bit more of your memory. here is why:
all your doing is telling the computer your creating a variable and giving it a value of (800000) so it will create this variable in memory using however much RAM prob 8bit and leaving it there until you restart your PC.... Notice you never release the variable.
