Speccy stuck on analyzing - Peripherals. What to do?
Hi there,
Windows 11 Pro / Product Version 11.1.2039.2
I just installed Speccy and it's analyzed everything except the peripheral section. It's pretty much stuck on it as it's taking forever.
How can I analyze this and see where it's stuck?
Thank you.
What peripherals do you have connected?
(peripheral devices include keyboards, mice, webcams, USB video devices, printers and faxes, virtual printers.etc.)
I would try disconnecting as many peripherals as you can and trying again.
If that works then add them back one by one and scan again after each one gas been connected, that should tell you which one is causing the problem.
If/when you find a problem one then disconnect it again and continue adding the rest one by one, there my be more than one that is problematic.
Hi nukecad. The only thing that's connected is a USB for a logitech wireless mouse. I've even removed the USB to see if it would resolve the issue. it didn't.
Not sure what happened, but it's working now ... weird.
Possibly unplugging/replugging the USB mouse receiver gave Windows Device Manager a poke.
When it was reinserted DM would regard it as a 'new' device and redo the setup for it.
Or if you've restarted your computer that may have given the necessary shake.
Odd things happen at times, as long as it's OK now.
