SPECCY reports SATA running at 1.5Gbps speed? Help anyone?
Hi People
Can someone help me with this.
I ran SPECCY and saw in the report that it says :
Used Transfer Mode SATA I 1.5Gb/s
I believe my motherboard is capable of SATA II 3.0Gbps speeds so I do not understand why this would be.
Drivers? BIOS?
First, I thought perhaps I should check if SPECCY was accurate in reporting this or if I am misreading it.
Unless anyone confirms this, I am thinking it is something off on my machine.
Anyone can help me figure this out?
Thanks for your time.
Peace & Blessings
D
HP Pavilion a6000n running Vista 32bit
Motherboard : ASUS M2N68-LA (Narra - GL8E) circa 2007??
probably a few things, what it could be...
bios-settings, old bios, driver, firmwares, incompatibilities with os, chipsetproblems with different kind of hardware and uncorrect programmed driver or whatever else... do you have the last driver from your pc-manufacturer?
i have read some ssds have a jumper for SATA-settings but your one i mean it dont have such jumper
