SPECCY QUESTİON
W.7 Home Premium
Hi All,
just got SPECCY and have this question.
When i shut down my laptop straight after that,
and booted again some 15 min later,to my suprise my
boot up time went up to a full 2 min.(from less then a min usually)
İs SPECCY known to cause that,i can't explain it otherwise
Thanks
there is nothing within speccy that would touch anything to do with system startup
Yes didn't think so either,
just wanted it confirmed.
Thanks
Some applications sometimes fail to close as quickly as one expects,
and this may interfere with or delay the Windows Shutdown process.
Could Shutdown aggravation result in Windows start-up taking a little more time before it is ready for action ?
I have Windows 7, 64 bit, home with 6 MB RAM. Speccy shows Memory size 6,144 MB, but Physical Memory part, it shows Total physical 3.24 GB, Total Virtual 6.48. And shows three slots used.
How to see all 6GB of Physical RAM?
josephab for anyone to answer your question you will have to start your own topic.
This topic now closed, OP can contact me or another moderator to reopen it if needed.
