speccy not working on win7 machine
I am using speccy mobile. When executed, speccy cannot return any information, It instead returns a "server execution failed" for each category. Result is same for v1.11.256 a v1.25.574
Anyone know why?
There seem to have only been a couple of posts about this error. One here..
http://forum.piriform.com/?showtopic=40106
I found this just now but obviously haven't tested it. Anything showing in the Windows Event Viewer at the time you try to run Speccy?
https://answers.syr.edu/pages/viewpage.action?pageId=918448
Also something worth looking at here
http://www.sevenforums.com/general-discussion/19417-server-execution-failed.html
Thanks for the info, but it has not helped resolve the problem, which is hard to troubleshoot withoout the code.
What condition causes display of the message?
Some of the conditions mentioned in my links cause the error.
Did you look in the Windows Event Viewer?
