Speccy not shown
Hi Guys/gals.
On my Vista laptop there is a link to Speccy next to CCleaner, Defraggler and Recuva but on My WinXP it doesn't show it. Now I've downloaded it to try and it works perfectly on both systems. I've changed to all the 3 forum styles and only 1 shows the other 3 apps. As anyone else noticed this?
Speccy work very good. I see we have a Speccy forum but no link. ;)
Have moved you to the speccy part of the forum :)
For me it is the old blue ccleaner style which shows nothing. Piriform 2009 and Piriform style both show it on xp for me.
I shall tell MrG about this.
Thanks for taking the trouble to post and welcome to the forums.
Thats ok Hazel I didn't notice the Speccy forum until I had posted.
I'm afraid the forum style makes no difference to my XP. The main links only show on Piriform style and the Speccy doesn't show but it does on my Vista. I'm not sure if IE8.0 makes the difference? ;)
I am using Opera
Speccy shows in Piriform style and Piriform 2009
In IE8 Speccy only shows in Piriform 2009
In ccleaner style nothing shows in either browser :(
Yes I've done a few tests. I uninstall IE8 which put back IE7. Speccy doesn't show in any forum style. I installed IE8 again and Speccy only shows in Piriform 2009 style as you say Hazel. So I will leave a link in here so other users that don't use IE8 can find it. I think these should be a pinned topic in this forum with a link to Speccy else users may not know it exists. I wouldn't have know about it if I didn't have my laptop. I haven't found any advantages to IE8 apart from seeing Speccy. I'm not installing FireFox or Opera, I've tried them and I don't like them. ;)
Speccy
