speccy not installed
just bought cleaner professional and installed it but when in came to install or run speccy the system info came up then the computer crashed and restarted but on windows the speccy program is just a shortcut and does not run what do i do to get it up and running?
Download the free version from https://piriform.com/speccy/builds and plug your registration into it (don't know the exact menu, sorry)
ok i've only run the cleaner but the speccy never got loaded it caused a crash but i will follow your advice on the registry if i ever do it but i now have speccy running thank you
