Speccy Install Tool problem
Hello and thanks for your help in advance.
I just purchased speccy and even though i am imputing the data correctly it wont accept it. Tried both copy paste and normal input methods. This is really really irritating.
g'day @Gorshalach and welcome,
some things to try.
if you copy/paste the Name: field make sure there is no extra space at the end after pasting.
if no luck, uninstall your current version, reboot your PC, then get the Free version from here; <a href="https://www.piriform.com/speccy/builds" rel="external nofollow">https://www.piriform.com/speccy/builds</a> and plug in your License Key to make it Pro.
you could try this link to get the key resent to your emails; <a href="https://www.piriform.com/support/license-lookup" rel="external nofollow">https://www.piriform.com/support/license-lookup</a>
or a support ticket can be raised from here; <a href="https://piriform.zendesk.com/hc/en-us/requests/new" rel="external nofollow">https://piriform.zendesk.com/hc/en-us/requests/new</a>
