When I run SPECCY a window pops up informing me that the program encountered a problem and needs to shut down. Please let me know if the trouble is in my computer.
What is Your Operating System and Service Patch Level ?
What is the exact message, including especially any error codes.
It would be so helpful if you would post the following:
- OS + SP #
- Speccy version #
- If this problem occurs only with Speccy, or if it happens with other programs u use.
Also, perhaps you can run Speccy in Debug mode, then post the logs here.
* Does Speccy run at all in Safe Mode?
To run in debug mode type this into your Windows Run Box (Including the quote marks)
"C:\program files\speccy\speccy.exe" /debug
(replace C:\program files\speccy with the location of your install)
