Speccy does not correctly read Crucial M4 SSD
Speccy version 1.18.379 does not seem to be correctly reading my SSD drive. The attached Summary picture shows the system info, and highlights the SSD in the hard drive list. The attached HardDrives picture shows that Speccy lists the manufacturer as "Unknown Manufacturer", and lists the Serial Number as 8-bit graphics characters. The SSD drive is actual a Crucial model M4 2.5" SSD (p/n: CT128M4SSD2). It would be very cool if Speccy would list the firmware version running on the drive as well. The motherboard is running version 3203 firmware (American Megatrends). The top two Hard Drives listed are both identical Seagate 3TB drives. I'm not sure why the first one is listed differently, but it's using a RAID controller so that the SSD can be used as a cache for it. The SSD is split into two partitions: A 64-GB partition (not listed) that is used as a cache for the first hard drive, and a 55 GB NTFS partition that you see listed as "55GB Volume_0000 (SATA)." The caching is handled by the Intel Rapid Storage Technology software, version 10.6.0.1002.
