Hi I Have speccy Version 1.19.411 Istalled On My Computer when I load speccy it analizes cpu, ram and motherboard then speccy displays and error message "LoadLibary Faild With Error 126: The specfied Module Could Not Be Found." Can Someone Please Help. I Am Running Windows 8 Pro 64-Bit OS. I Have Uninstalled The Software And Reinstalled It And I Still Recieve The Error Message. Thanks Shawn
please run Speccy in Debug mode
http://www.piriform.com/docs/speccy/troubleshooting-speccy/running-speccy-in-debug-mode
then post the log here at this thread as an attachment, you may have to change its extension from .log to .txt
Hello Nergal, When I Run Speccy In Debug Mode I Get The Same Error Message Plus A Message That Says No Update Advabile I Have Attached A Screen Shot. Do You Have Any Other Ideas.
Try a program called "Windows Repair" (WR) (www.tweaking.com) and run it with - at least - the box called "Repair WMI" ticked. WR can solve a significant amount of problems. If it helps you then post a reply in this thread.
I expect you to get the same result, and debug mode always checks for updates. Please attach the created logfile from the debug as an attachment
@Willy, I'm not sure that's his issue as other components load, is there any harm in running the utility if wmi functions?
Hi Nergal, i can get any log file everytime i load speccy even in debug mode i get the error message the the program closes i gone to try that window repair thing. i will post back later and let you know what happens thanks Shawn
Not Willie, but it shouldn't do any harm.
Hey I Tried The Windows Repair It Did Not Fix The Issue But It Fix Some Other Issues I was Having lol. is The Anything Else I Can Try nergal? and hazlenut i am sorry but i am not downloading that simple .reg file i dont trust it but thanks. Shawn
Hi Shawn, and welcome to the forum.
I found the same fix that hazel links to, and it seems to have fixed an awful lot of those errors, and If you already have "Windows Repair", you could use it to back up the registry, and restore it if the reg fix doesn't work.
I would suggest at least having a look at the location the reg file is targeted at, and this is the actual contents of that reg file ...
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4d36e968-e325-11ce-bfc1-08002be10318}\0000]
"OpenGLVendorName"=hex(7):61,00,74,00,69,00,6f,00,36,00,61,00,78,00,78,00,2e,\
00,64,00,6c,00,6c,00,00,00,61,00,74,00,69,00,6f,00,36,00,61,00,78,00,78,00,\
2e,00,64,00,6c,00,6c,00,00,00,00,00
It apparently puts right what is an error in the "OpenGLVendorName" entry.
All this ties in with "method 3" of hazels 2nd link, and one of the links I found last night, which shows very clearly in screenshots what the problem is supposed to be. And a copy of the same reg fix.
http://servicecore.i...indows-systems/
You should at least fire up regedit, and check out that registry location, and see what you have in there.
An alternative to backing up the registry would be to "export" the original entry to a safe location, and if nothing changes after trying the fix, then just merge the exported original entry back into the registry.
Your choice of course Shawn.
Thank you All For Your Help My speccy Is Working!! And Thanks Hazelnut and DennisD For Providing The Fix. Happy Holidays Everyone! Shawn
@Noobkiller: "Registry Backup" (www.Tweaking.com) is a great tool to backup the registry. No need to use "Windows Repair" when one only wants to backup the registry. I am glad "Window Repair" fixed a number of problems.
Same to you Shawn. Pleased you fixed it.
