Speccy and Firewall
I use Online Armor and allow Speccy to run as a trusted program but it keeps making new random files like this located in C:\documents and settings\user\local settings\temp\xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx
20509474037101676659702064speccy.sys
Windows ® Codename Longhorn DDK provider
Windows ® Codename Longhorn DDK driver
If I close the program I have to allow a new random named program to run again, so I was wondering if there is there any way to keep the file name consistent so online armor recognizes it's a safe program?
If I block it it will say "access denied" under "Graphics"
Speccy doesn't do anything with programs it just shows system spec.
If you get "access denied" under "Graphics" then your not running as an admin. ;)
Have you tried putting Speccy as an exclusion in Online Armor?
Options>exclusions and tick include subfolders.
