Latest version fails same as about last 6 versions
Program starts and then box appear saying program has ended unexpectedly
running in debug without graphics all o/k
if run with graphics selected fails
no dump created also is task manager run will not all dump access rights
only log file available
[2012-12-03 22:10:41] [iNFO ] CPUIDSDK()
[2012-12-03 22:10:41] [iNFO ] CPUIDSDK::InitDll
[2012-12-03 22:10:41] [iNFO ] CPU SDK at: C:\Users\Ken\AppData\Local\Temp speccycpuid.dll
[2012-12-03 22:10:45] [iNFO ] CPU dll init OK
[2012-12-03 22:10:45] [iNFO ] Monitor enumerator handle: 0x3866650h
[2012-12-03 22:10:45] [iNFO ] Monitor HardwareId: MONITOR\TOS5091 DriverId: {4d36e96e-e325-11ce-bfc1-08002be10318}\0001
[2012-12-03 22:10:45] [iNFO ] Monitor driver name: Intel® HD Graphics
[2012-12-03 22:10:45] [iNFO ] Monitor mirroring driver: False
[2012-12-03 22:10:45] [iNFO ] Monitor display device active: True
[2012-12-03 22:10:45] [iNFO ] monitor device ID = < MONITOR\TOS5091\{4d36e96e-e325-11ce-bfc1-08002be10318}\0001 >
[2012-12-03 22:10:45] [iNFO ] continue with monitor device ID = < MONITOR\TOS5091\{4d36e96e-e325-11ce-bfc1-08002be10318}\0001 >
[2012-12-03 22:10:45] [iNFO ] monitorNameStr.IsEmpty()
[2012-12-03 22:10:45] [iNFO ] monitorNameStr = < Generic PnP Monitor >
[2012-12-03 22:10:45] [iNFO ] continue with monitor device ID = < >
[2012-12-03 22:10:45] [iNFO ] monitorNameStr = < >
[2012-12-03 22:10:45] [iNFO ] Monitor driver name: RDPDD Chained DD
[2012-12-03 22:10:45] [iNFO ] Monitor mirroring driver: True
[2012-12-03 22:10:45] [iNFO ] Monitor driver name: RDP Encoder Mirror Driver
[2012-12-03 22:10:45] [iNFO ] Monitor driver name: RDP Reflector Display Driver
[2012-12-03 22:10:45] [iNFO ] Driver: Try to load driver.
[2012-12-03 22:10:45] [iNFO ] Driver: Load driver OK.
[2012-12-03 22:10:45] [iNFO ] VIDEO DEVICE DRIVER
[2012-12-03 22:10:45] [iNFO ] TryGetSelectedDriverAndFill START
[2012-12-03 22:10:45] [iNFO ] GetSelectedDriver ret false
[2012-12-03 22:10:45] [iNFO ] TrySelectDriverAndFill START
[2012-12-03 22:10:45] [iNFO ] OpenRegKey
[2012-12-03 22:10:45] [iNFO ] InfPath from registry oem10.inf
[2012-12-03 22:10:45] [iNFO ] ProviderName from registry Intel Corporation
[2012-12-03 22:10:45] [iNFO ] DriverVersion from registry 8.15.10.2189
[2012-12-03 22:10:45] [iNFO ] SetDeviceInstallParams
[2012-12-03 22:10:45] [iNFO ] DiBuildDriverInfoList Succeed=1
[2012-12-03 22:10:45] [iNFO ] GetProperty SPDRP_MFG = Intel Corporation
[2012-12-03 22:10:45] [iNFO ] GetProperty SPDRP_DEVICEDESC = Intel® HD Graphics
[2012-12-03 22:10:45] [iNFO ] SetSelectedDriver
[2012-12-03 22:10:45] [iNFO ] TryFillDriversFromDrvinfo START
[2012-12-03 22:10:45] [iNFO ] QueueCallback START
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\DRIVERS\igdkmd64.sys
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igdumd64.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igd10umd64.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igkrng575.bin
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igcompkrng575.bin
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfcg575m.bin
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\igkrng575.bin
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\igcompkrng575.bin
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\igfcg575m.bin
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\iglhxs64.vp
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\iglhxo64.vp
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\iglhxc64.vp
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\iglhxg64.vp
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\iglhxa64.vp
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\iglhxa64.cpa
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\iglhcp64.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\iglhsip64.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\igdumd32.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\igdumdx32.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\igfxdv32.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\igd10umd32.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\iglhcp32.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\iglhsip32.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\difx64.exe
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\hccutils.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxsrvc.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxsrvc.exe
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxpph.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxcpl.cpl
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxdev.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxdo.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxtray.exe
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\hkcmd.exe
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxress.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxpers.exe
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxTMM.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\gfxSrvc.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\GfxUI.exe
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\GfxUI.exe.config
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\IGFXDEVLib.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxext.exe
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxexps.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\igfxexps32.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrara.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrchs.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrcht.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrdan.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrdeu.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrenu.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxresn.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrfin.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrfra.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrheb.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrita.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrjpn.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrkor.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrnld.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrnor.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrplk.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrptb.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrptg.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrrus.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrsky.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrslv.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrsve.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrtha.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrcsy.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrell.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrhun.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxrtrk.lrc
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.ar-SA.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.cs-CZ.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.da-DK.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.de-DE.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.el-GR.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.es-ES.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.en-US.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.fi-FI.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.fr-FR.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.he-IL.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.hu-HU.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.it-IT.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.ja-JP.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.ko-KR.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.nb-NO.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.nl-NL.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.pl-PL.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.pt-BR.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.pt-PT.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.ru-RU.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.sk-SK.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.sl-SI.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.sv-SE.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.th-TH.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.tr-TR.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.zh-CN.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\Gfxres.zh-TW.resources
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\ig4icd64.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\SysWow64\ig4icd32.dll
[2012-12-03 22:10:45] [iNFO ] TryAddFile C:\Windows\system32\igfxCoIn_v2189.dll
[2012-12-03 22:10:45] [iNFO ] TryFillDriversFromDrvinfo END
[2012-12-03 22:10:45] [iNFO ] addr version 8.15.10.2189
[2012-12-03 22:10:45] [iNFO ] No pointer
[2012-12-03 22:10:45] [iNFO ] Driver: Driver unload OK.
[2012-12-03 22:10:45] [iNFO ] FillWmiVideo 1 objects
[2012-12-03 22:10:45] [iNFO ] Name=Intel® HD Graphics
[2012-12-03 22:10:45] [iNFO ] DriverVersion=8.15.10.2189
