Hi there,
After installing an update to 1.17 I am getting "No such interface supported" instead of all results.
I am not a programmer anymore for ten years, so can't crack this one and suggest the resolution.
Thus would you please have a look at it.
The file is attached to this posting.
Cheers
M
Nergal
July 30, 2012, 2:39am
2
make sure the wmi service is running
if it is. Run speccy from command line with a /debug switch and you'll find a log created in the speccy folder. Post it as an attachment to this thread.
Willy2
July 30, 2012, 11:37am
3
@Eastexpert,
If the WMI part of Windows is to blame (as Nergal suggests) then do the following:
- download the program called "Windows Repair" (WR) (www.tweaking.com)
- tick the "Repair WMI" box.
- hit start (in WR)
- rerun Speccy and see what pops up.
Perhaps you need to tick the box "Set window services to startup default" in WR as well.
And above all: Let us know if this was helpful.
Nergal
July 30, 2012, 2:03pm
4
that's only if the issue is with WMI. I was spitballing, we should let the OP answer if it is running or not before making suggestions.
Willy2
July 30, 2012, 2:19pm
5
I know. After all, I wrote "If". But I know WMI is used to pull up A LOT OF computer info.
