Make sure the master volume is not turned down. control panel>sounds and audio devices. If not that than the sound cards probably trashed. Tell your friend to go buy a cheap sound card ( you can find really really crappy ones for $15 or less). This sounds like an entry/learning pc anyway. So if your friend gets a year or two out of it he would probably want a new one anyway.
Yeah, and make sure nothing has mute check marked. You may want to try some headphones on the output jack as well just to make sure the soundcard is alright. Probably wouldn't hurt to check Control Panel->Device Manager->Sound, video and game controllers.
And another possibility is to open the PC case completely unplug the sound card. Look at the line of connectors, if they're dirty (or just for the fun of it) cleaning them with a pencil erasing can help to remove any clag.
Check that you're using powered speakers. If your speakers don't have a light and/or a volume knob, then most likely your speakers are unpowered [well, the speakers should also have to be plugged into the wall outlet in order for them to work. If there's no wall outlet power required, then you're using the wrong speakers]. Onboard audio doesn't have an amplifier (especially VIA's). Get powered speakers.
You seemed to be the only one to notice that I said it was an onboard sound chip, and you are right about the speakers, they are unpowered, I'll take a set of mine into work to try it.
I didnt even know they made unpowered computer speakers. Even the cheap piece of crap ones that came with my pc are powered. something to look out for I guess.
