Sound at Finish
How about a feature to enable/disable a customizable sound to get our attention when the work is done... this is very usefull when a PC is full of crap and you know is gona take a bit longer to get cleaned... you can spend your time doing anything else and leave CC in task bar running and the sound will tell you when CC finish its work... ;)
Don't know if this feature was already requested but I don't have lot of time to spend searching in this very long history forum... so sorry is this got duplicated :P hope it's not...
I like the idea.
