hello:)
i have some proposals to the Ccleaner:P
fist i think it would be good if you canse how big size the program/game are in the uninstall tool!
and the second thought is that in the cleaner menu, when you has analyze your system the program shows you a picture of youre harddrive in a round diagram and it shows in "%" how mutch free space you have and how mutch you have used and in the used part it shows how mutch you can clean in "%".
tha last tip i have is that in options it would be good if there was at "start ccleaner att startup" so maby it can auto run and clean or something.
hi again!
onte more thing if you look at www.diskcleaner.nl and download the program it removes a lot of things, so if you se some remove funcions that not are in ccleaner you can add them!
