Some help with my registry
Ok, so I did a scan with CCleaner for registry bugs. I managed to fix quite a bit, but there's still a significant amount of them left that I am unsure about.
Here's what's left:
Unused File Extension SysmonLogManager.Snapin HKCR\SysmonLogManager.Snapin
Invalid Default Icon C:\Program Files\Adobe\Acrobat 7.0\Acrobat\AcroRd32.exe HKCR\acrobat\DefaultIcon
ActiveX/COM Issue ADCS - {89E30300-764D-11d0-B282-00A0C90F56FC} HKCR\ADCS
ActiveX/COM Issue BDATuner.Explorer.1 - {971E14B5-D75E-F58E-34EE-25B80B838BD3} HKCR\BDATuner.Explorer.1
Invalid Default Icon C:\WINDOWS\system32\CMMGR32.EXE,1 HKCR\Connection Manager Profile\DefaultIcon
Open with Application Issue C:\WINDOWS\system32\CMMGR32.EXE "%1" HKCR\Connection Manager Profile\shell\open
Open with Application Issue C:\WINDOWS\system32\CMMGR32.EXE /settings "%1" HKCR\Connection Manager Profile\shell\Settings...
ActiveX/COM Issue Microsoft.OOBE - {93BB835D-86FF-2975-6133-6256EAD8C7D2} HKCR\Microsoft.OOBE
ActiveX/COM Issue InProcServer32\C:\WINDOWS\system32\macromed\flash\flash.ocx HKCR\CLSID\{1171A62F-05D2-11D1-83FC-00A0C9089C5A}
Open with Application Issue Applications\moviemk.exe\shell HKCR\Applications\moviemk.exe
Application Paths Issue cmmgr32.exe - C:\WINDOWS\system32\cmmgr32.exe HKLM\Software\Microsoft\Windows\CurrentVersion\App Paths\cmmgr32.exe
Installer Reference Issue C:\WINDOWS\winsxs\x86_Microsoft.VC80.ATL_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_6e805841 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\WINDOWS\winsxs\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_dec6ddd2 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\WINDOWS\winsxs\x86_Microsoft.VC80.MFCLOC_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_3415f6d0 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Installer Reference Issue C:\WINDOWS\winsxs\x86_Microsoft.VC80.OpenMP_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0ee63867 HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\Folders
Uninstaller Reference Issue {A49F249F-0C91-497F-86DF-B2585E8E76B7} HKLM\Software\Microsoft\Windows\CurrentVersion\App Management\ARPCache\{A49F249F-0C91-497F-86DF-B2585E8E76B7}
Obsolete software key AppDataLow HKCU\Software\AppDataLow
Obsolete software key AppDataLow HKLM\Software\AppDataLow
Obsolete software key InstalledOptions HKLM\Software\InstalledOptions
if anyone could tell me what I can safely delete and what I should keep.. that'd be greatly appreciated :)
-zonderling
I think that the best advice is not to worry about the registry too much. I only run a scan on mine at monthly intervals, if I remember, and then I hardly delete anything. It won't make much difference either to speed or space if you remove these entries, although I appreciate that CC will look much cleaner.
