Some files left after cleaning?
Hello! I have a question about disk space. Now i show you what is hapening on my pc.
1. my disk space is 6.084.881.920 bytes
2. I have opened mozilla firefox, now my disk space is 6.083.329.536 bytes
3. I have closed mizilla firefox, now my disk space is 6.083.694.080 bytes
4. I have used CCleaner, now my disk space is 6.084.816.384 bytes
6.084.881.920 - 6.084.816.384 = 65.536 bytes is not cleaned. Why CCleaner has not cleaned all the files? What are these files?
Thanks for answers
P.S. sorry for grammar if its not good.
CC does not clean every file used when you use an application such as Firefox. There are logs, swap files, all the stuff that Windows thinks it needs to live and breathe. CC will (should) clean all the files it analyses. If you think that CC isn't cleaning something it should then post the file names here and we'll try to sort it.
Thank you Augeas ,now I understand why my disk space is lowing. And by the way CCleaner is deleting everything that he analysis. Thanks again :rolleyes:
By the way ,are you having the same numbers? :huh:
I have ran two crap cleaners your side by side with another wich is only part of a bigger program and not its main feature.
I ran CCleaner and wiped out a 180MB'ish of all sorts... Then I ran the other I mean straight after another 121 temp files were wiped releasing an extra 96MB...
I will try and find a log and post it here.....
Ah also the sqm files in xp are not getting cleaned those are messenger something or others arent they? C:/ hidden files? yea I noticed that dont knwo why but in vista its workig ok on that front.
