I have gone through the beginners guide and forum and still do not understand the following:
When cleaning windows and applications(other than temp files)what sort of files are this? for example office,antivirus and other applications and of course windows? Will I potentially disable some functions if I delete these files?I'm on default settings. Thanks in advance for your reply.
