Smart cleaning option's choices changed with 6.20.10897
My browser automatic cleaning setting changed from "prompt toclean on closing" to "automatic cleaning with notification".
Was it just a regular update from 6.19?
I know that it will automatically turn Smart Cleaning on and set that "automatic cleaning with notification" option for browsers when you enter or re-enter a licence key to register the Free version as Pro.
8 hours ago, nukecad said:
Yup regular update. no reenter of license. I changed back but posted this topic in case others ran into the same.
Dunno then, I guess most Pro users would do the same if it does happen and just change it back to how they want it.
