Smart Cleaning alerts
Hello,
I would like to know the meaning of this alert where the color is blue. I read in the Help section (What is the Smart Cleaning feature? – Piriform Support) that there are red and yellow notifications but not blue. Thanks to clarify.
It's informing you that the minimum limit has been reached and is asking you do you want to clean. That said yours is quite low at 1/2 a GB. You can set this limit in options>smart cleaning. I have mine set to the default 1GB.
Hi Nergal,
Thank you for your answer. May be the Help section is not updated? Because it isn´t mentioned any blue alert.
The blue is just a piriform color it isn't (too my knowledge) a color coded message
Therefore, the Help should be updated. Currently, it appears the following:
But never a blue alert is mentioned.
