I was able to type an address without the www. and .com by pressing control before enter. like id type[ yahoo ] then press ctrl then enter and it would add the www. and the .com. However, now it does nothing at all. This is most annoying as it is a feature I tend to use often. A solution would be handy. Thanks.
1. Open Internet Explorer.
In the menu click Tools->Internet Options->Advanced tab make sure you have enabled "Use inline Autocomplete" then click OK to save the setting if it isn't already selected. Note: The setting isn't selected with Internet Explorer's default settings.
2. Open CCleaner.
In Cleaner Settings->Windows->Internet Explorer uncheck "Autocomplete Form History"
Enjoy yourself boots/Mr. Clean, I hope you enjoy getting banned.
lol his spam is hillarious. offensive but hillarious
