Small improvement (cosmetic)
Hello,
I suggest to highlight the line of the file being defragged, then to remove it from the list if the fragment number reaches one after defragmentation.
  • In the popup windows, the name can be ambiguous because it is truncated when too long. Highlighting the line would be more obvious.
  • Removing the line would simplify the list.
Thanks for the product,
Jean-Dominique
