mooms
1
Hi,
I have specially registered to report this bug:
Since a few versions, when you install silently CCleaner slim (/S switch), it starts in English, and I have to manually change the language.
Older versions didn't have this bug, they always starts with correct language at the first start.
Regards.
Nergal
2
? how does it know the correct lang without setting it?
mooms
3
Hi Nergal,
That's not the point, but it's actually very simple, the installer retrieves the Windows language variable, that's all.
Edit: It's not a bug, it's a feature!
Previous versions settled the language automatically, according to the system language, seems the devs had problems with this.
Nergal
4
actually probably some users had a problem with it (lots of users run apps in langs different from locale I guess :S
