Small bug with build v1.02.085
Hi,
There is a small bug with build v1.02.085 : the defrag drive menu item is always enabled even if defragmenting.
Defraggler will hangs if you click on this menu item while defragmenting.
Steps to reproduce this issue
- Start Defraggler
- Click on the Defrag button
- Click on the Action menu and select "defrag drive"
Act : application will hangs
Expt : "defrag drive" should be disabled
Workarround : kill the apps
FWIW I'm running on Vista Pro SP1
BR
Stephane
Well spotted !
Tried this under XP Pro, with same results [as expected].
