Slow Start up
Nice one dennis, if you noticed in my script i delete it, Pointless i know since it will re spawn every few seconds from system32, but made me feel better lol
Only info i found on it (didn't spend much time looking) was from m$ saying go to add remove etc but the component it listed was not present.
I didn't notice that, sorry.
It's a pest for sure in XP, and best got rid of.
EDIT: Found it.. Annoying ctfmon.exe. :)
I hope, your solution sorts it. Be glad to get rid of it.
yeh it is very annoying :D
Hi Dennis thanks for the suggestion have done that,still on my three minute mile !
I am doing a full Avast,Superantispyware and Malwarebytes scans again to make double sure there`s nothing nasty,
then i`ll defrag..
Something seems to point to Online Armor in that that i tried again to not auto start it up like Hazlenut suggested and
my screen is populated instantly but then i get failures in Avast with the relatime shields being knocked out..
had a quick look at their O.A forum but can`t find anyone having similar
(I think it`s official now from the Significant Other..that the computer is slow and it`s my fault.. because.."you`ve been fiddling about") :blink:
I really think your best bet is to uninstall OA, reboot twice, make sure avast is running correctly and then reinstall OA using a trust all option.
Then see how it goes.
There should be no reason using OA and avast that you have this slowdown.
Good News to report !
I`ve done what you have suggested Hazelnut and I uninstalled Online Armor..
I had to check that Avast was running ok..but it was playing up.i was getting program not responding ,so i have uninstalled and reinstalled Avast and now reinstalled O.A
Both seem to be running and behaving themselves yippee !!
I have done a scan to make sure everthing is still as it was
(actually i did a boot scan with Avast and it has found an archive corrupted in windows office,but i will look at this and prob post a quick question about it)
But the great news is..it seems to have worked and now I do not have a three minute wait,everything is there straight away !
So I just want to thank all of you who posted and gave me assistance and ideas it truly is appreciated... :)
Fluff
Glad to hear you have got this problem about your slow boot sorted Fluffy.
We all learn things from these threads :)
