slow deleting of entries in listbox under "issues"
If there are many problems found under "issues", the list is very long.
After the program fixed the problems, it clears that listbox.
But the clearing-process it is very slow, because it deletes each item of the listbox after each other.
As I programmed in Borland Delphi, it had this problem, too.
But I solved it in that way:
First hiding the listbox, then clearing it and then make it visible again. That's much faster!
I hope you know what I mean. :)
Haha, I know what you mean. I wrote Dial-a-fix in Delphi 7.
Better than hiding the box itself is to use the included BeginUpdate and EndUpdate methods:
ListBox1.BeginUpdate;
<insert or delete stuff>
ListBox1.EndUpdate;
I hate VB (which is what CCleaner is written in) :D
But not only that, most of the components on the form are non-standard even to VB (note all of the OCXs that get installed, ugh)
I also hate the way HijackThis does smooth scrolling (long pause during the first vertical scroll, then it gets back to normal speed)
thanks! I wasn't aware of these two methods.
Did the programmer of ccleaner read this thread?
Will this be implemented in ccleaner ?
Now talking programming language...
What about VB.NET
I am programming in it and it seems very easy. Visual Studio does help.
Would CCleaner be better if it was written in .Net.
I see one (big) problem - you have to download the Framework runtime
But generally, isn't it better?
It's a managed language, so garbage collection and most memory functions are handled by the runtime rather than the developer. .NET seems to be for RAD (rapid application development) the way VB is, but with managed code (VB is unmanaged). C++ is unmanaged, and so is Delphi, etc. I would say CCleaner would not be better in .NET.
Well, that means one thing - CCleaner should not be programmet in VB.Net :)
However I agree, that the ListBox should be fixed
I often clean others computers, and it is a pain in the #?@ to clean 300+ threads on a slow computer
Hope it will be fixed soon :)
I mentioned this in an earlier thread. In VB and VB.Net, most controls have a Redraw property. Just set it to False, call the Clear, and then set the Redraw to True. The last set to Redraw = True, refreshes the control and contents. This also works when doing selective as well. Just do the Redraw=False, Clear
item(s), Redraw=True and the new listbox items will be displayed (provided you kept the contents un-selected).
I also hope that eventually the progressbar is fixed as well as the Fix Selected issues ...
When fixing all items and the listbox is cleared, the progressbar is still set to 100% (should be reset to 0%) and the Fix Selected issues ... button is still enabled (should be disabled since the list is cleared).
But these are just cosmetic ... that only program developers mostely see.
Are developers informed of this?
I hope this small, but annoying bug will be fixed soon :)
