Although this is a SliTaz thread, any info on linux issues I think is relevant, and the screen alignment issue is definitely the result of refresh rate.
XP displays properly at 60hz, and if I change that to 70hz, it still displays clearly with no glitches/flickering, but it jumps across to the side.
And if you want to have a run at Ubuntu and save changes onto a USB, then you can set it to be "persistent" by installing it with "Universal USB Installer". Whether you can do it via a "superuser" account as you can in SliTaz, I don't know. Re-installing is probably quicker than searching for, and then applying a different method, if there is one.
I use Universal USB Installer to embed my Linuxes on my USB flashdrives but it requires me maybe 700 MB to actually put this SliTaz on the USB.
Ishi, did you ever get it sorted out to your satisfaction? Asking because I just used Dennis's procedure to put Slitaz with the new apps onto the original USB, and it occupies only about 116 mb.
Thank you muchly, Hazel. I just tried it, stopped short of an installation...no need, and anyway I'm out of usb sticks. Wow. It will either install an iso you already have "on file" or download it. Has links to a big list of available distros.
I'm not a newbie! i just signed in now
<span class="ipsEmoji">?</span><span class="ipsEmoji">?</span></p>
You are new to the forum, (and I'm afraid it shows).
You have just replied a 9 years old post, the version of SliTaz being discussed here (v3.0) is well out of date.
SliTaz is now at version 5.0.
Please check the date when a post was last replied to before adding your own replies.
