removed
I'm sure the problem is a registry entry for the recycle bin but have no clue which one. Maybe there is a program out there that can replace the recycle bin if you need the functionality.
mrr. I don't need it, persay. But I do like to keep things in there until I delete them, sometimes I mistakenly delete files I want (I had to remove a rootkit once, and almost deleted my realtek audio driver :x) and this would cause major problems. I'll look into a program to fix this though.
Edit: Problem Solved, I had to Shift-Delete the C:\RECYCLER directory so windows could re-write the corrupted info files. Thank you for helping me .
