Skipping all edge & IE items how do I turn back on
While analyzing my system CCleaner asked if I wanted to close edge I said yes but also checked the box not to ask that question again. I was thinking it would remember my choice as force close edge not skip all edge components. How can I turn on the edge and Internet explorer cleaning? I have looked at the existing posts but they don't seem to hit this issue.
I appreciate your help!
Go to Options > Advanced
Untick the box next to "hide warning messages".
Generally CC skips if the browser or one of it's components is still open.
Give it a bit of time (10 seconds?) between closing the browser and running CC to give everything time to close properly and it should stop the skipping.
