SimpleOCR problem
I am using the program "SimpleOCR" and when I attempt to change the 'default' scanner to another in the list, the change does not *stick*.
After going to options and changing the default scanner and then try to scan - the old default scanner does the scanning and when I again go to options, the old default scanner is still the default.
How do I change the scanner so it DOES scan from the one I choose?
Perhaps you can make it the default scanner in Control Panel -> Scanners and Cameras
Unfortunately, there is no 'default' choice for the scanners in the control panel.
Got another idea?
(Sorry for the long delay - I did NOT receive notification of your reply (even though the options say send notification.)
Got another idea?
Nope, that was the only one.
