Silent uninstall of CCleaner v3.03 does not work?
It seems like in the newest CCleaner v3.03.1366 the silent uninstall option of "uninst.exe -S" that previously worked has now been removed. The same goes for Defraggler v2.02.253, "uninst.exe -S" doesn't work here either. If I try to run them as above, a GUI for uninstalling shows, requiring manual input.
Any clues as to why? Anyone have a workaround?
(I know the GUIs may be manipulated with AutoIt scripts or similar tools, but there is a need for silent uninstalls without user interaction and knowledge.)
Kind regards,
MrOlrich
Kind regards,
MrOlrich
Bump.
Does anyone have a solution to this yet, or at least a workaround (except for AutoIt-scripting a GUI uninstall)?
MrOlrich
Never mind. New downloads of both CCleaner and Defraggler, silent install and uninstall (of slim versions) with /S, now work.
Found another post somewhere about Piriform delaying publishing slim/free versions. I'll attribute this anomaly to that.
Good evening!
MrOlrich
Hi Mr Olrich.
Although you didn't get a reply, probably because no one actually new the cause of your issue, I'm pleased it's sorted now.
Welcome to the forum by the way.
