I have tried the "/s" silent install switches with both the standard and slim installers for both ccleaner and defraggler, neither of which work. Even trying /lang=1033 doesn't bypass the initial language prompt. I thought the installer was compiled with Inno, so I tried it's standard setup switches /silent, /verysilent, /sp- and even the /log to see if that will create a log (it didn't)... I've also tried some common ones for other setup packages like /q, /quiet, /passive, etc. all to no avail.
So what gives with /s?
Would it be ok to repackage the portable versions of these apps with my own installer that I can run silently for automation purposes? Is there anything I should concern myself with by using this method?
In consideration of your agreeing to abide by the terms of this Licence and subject to your compliance with the terms of this Licence, Piriform grants you a non-exclusive, non-transferable licence to use the software in the following manner and for the following purposes:
- You may NOT resell, charge for, sub-license, rent, lease, loan or distribute the software without our prior written consent. We reserve the right to withdraw any such consent (or part thereof) for any reason and without notice and to demand that you immediately cease any activity in respect of which permission is withdrawn.
- You may NOT repackage, translate, adapt, vary, modify, alter, create derivative works based upon, or integrate any other computer programs with, the software in whole or in part.
- You may not use the software to engage in or allow others to engage in any illegal activity.
- You may NOT transfer or assign your rights or obligation under this Licence to any person or authorise all or any part of the software to be copied on to another user's computer.
- You may NOT decompile, disassemble, reverse engineer or otherwise attempt to discover the source code of the software except to the extent that you may be expressly permitted to reverse engineer or decompile under applicable law.
I'm going to say no you can't. why so want the /s install?
