I'd love to see a feature that would allow users the option to shutdown the computer, put it into sleep mode, or into hibernation after manually running CCleaner.
I often manually run CCleaner when I'm done using my computer. It takes a minute or two to run, and I have sit & wait for it to finish before I can put my machine into sleep mode. I would be great to be able to start CCleaner & just walk away, letting it clean & then shut things down automatically.
Something similar to this is Auto Shutdown 3.6.2D - an add-on for Firefox that allows this type of control after all downloads complete. I find it very useful.
Thanks for the suggestion Alan! It is helpful. Now is there also an option for the command line "CCleaner.exe /AUTO /SLEEP"?
Personally, however, I'd prefer to avoid using command line at all. After all, I'm lazy enough that I don't want to wait around to put it into sleep mode myself after I've run CCleaner. I'd just like it to run quickly & easily, then put my computer to sleep when it's done. It would be great to just go into advanced settings & tick a little box beside something worded like "Close program & put computer into sleep mode after cleaning."
