Shutdown after cleaning
Downloaded latest version and it no longer has option to shutdown after cleaning....
What is the reason for that, I really liked that option
It's located in (tip: maximize the GUI for Advanced to show):
Options -> Advanced
If you prefer to use the command-line parameters for it instead (in shortcuts, batch files, scripts, etc.,), see here:
http://www.piriform.com/docs/ccleaner/advanced-usage/command-line-parameters
Edit:
Since you're the second person to bring something like this up. I've reported it to the admin because if the GUI is sized too small the 'Advanced' button completely disappears.
Thanks, if not full screen the advanced button does not appear....
