ive never had a problem with ccleaner then bout the professional addition , works fine only problem just a small but annoying one at the top were it shows operating system, it shows as vista im using windows 7 how do I correct this?
Can you provide a screenshot?
What version of windows are you running specifically (eg: windows 7 professional x64) and what version of Windows does CCleaner say you are running?
also include a screenshot of Control Panel, System as that will show the Windows Edition that Windows thinks is on your PC then that can be compared with the CC screenshot of what it thinks is on your PC.
I have windows 7 that's what my computer shows as well but cleaner shows windows vista, think maybe a windows update or cleaner update caused this?
forgot to mention its windows 7 32 bit is my sysyem as stated cleaner thinks its vista
On your machine go to 'Start' (the orb bottom left of taskbar) then right-click on 'Computer' and select 'properties'.
What details does it show there about your machine?
hazel its shows windows 7
Is it Windows 7 Home premium with Service Pack 1?
Did you buy the machine with Windows 7 already installed or did you upgrade to Windows 7 from Vista?
it use to have xp its been upgraded to windows 7 home premium sp 1
1. Did you do the upgrade yourself?
2. Did you use a Win 7 full install disk?
3. Did you do this recently?
4. Did this problem of ccleaner showing vista only start after you installed the professional version?
5. If you used the free version before did this show Win 7 correctly?
nope had a prfessinal install windows 7 this was 2 yrs ago no problems I installed the pro version it worked fine but deleted it once decided to reinstall that's when problem occured
What happens if you uninstall ccleaner pro, reboot, and install the slim build from here?
http://www.piriform.com/ccleaner/builds
Does it show Win 7 or Vista?
downloaded from your link still shows vista
a screenshot of @hazelnut's post #6 and another of CC running would be nice.
but since you have the Professional version, you are entitled to direct support from Piriform, http://www.piriform.com/support
Jason could you run Speccy and see what operating system that shows please?
it shows windows 7 hazel
Jason, thanks for the information. This issue will be reviewed by dev.
Hi Jasont42,
Unfortunately, we haven't been able to reproduce in our testing labs.
Can you please update to the latest version of CCleaner?
Please let us know if you still having this problem after updating.
Thanks
MrT
yes ive updated to lastest version
