Show hard drive RPM
There are only 2 free system information utilities that I know of that show hdd rpm: the discontinued Everest Home 2.20 and the rather large SiSoft Sandra Lite.
It sure would be nice to have that info in Speccy.
(A friend had a replacement hdd installed, and I wanted to make sure it was what was ordered.)
Speccy shows my 7200.
The 2 programs mentioned show 7200 rpm for my hdd. Speccy only shows the following:
Hard Drives
Hitachi HTS721060G9SA00
Manufacturer Hitachi
Product Family Travelstar
Series Prefix Standard
Model Capacity For This Specific Drive 100GB
Heads 16
Cylinders 16383
SATA type SATA-II 3.0Gb/s
Device type Fixed
ATA Standard ATA/ATAPI-7
LBA Size 48-bit LBA
Power On Count 2870 times
Power On Time 620.5 days
Features S.M.A.R.T., APM, AAM, NCQ
Transfer Mode SATA I
Interface SATA
Capacity 59GB
Real size 60,011,642,880 bytes
RAID Type None
S.M.A.R.T
01 Read Error Rate 100 (100 worst) Data 0000000000
02 Throughput Performance 117 (117) Data 0000000D0D
03 Spin-Up Time 245 (245) Data 0000000001
04 Start/Stop Count 099 (099) Data 0000000B36
05 Reallocated Sectors Count 100 (100) Data 0000000000
07 Seek Error Rate 100 (100) Data 0000000000
08 Seek Time Performance 118 (118) Data 0000000025
09 Power-On Hours (POH) 066 (066) Data 0000003A2C
0A Spin Retry Count 100 (100) Data 0000000000
0C Device Power Cycle Count 099 (099) Data 0000000B36
BF G-sense error rate 100 (100) Data 0000000000
C0 Power-off Retract Count 099 (099) Data 00000000CE
C1 Load/Unload Cycle Count 058 (058) Data 0000066AE9
C2 Temperature 125 (125) Data 00FFFE002C
C4 Reallocation Event Count 100 (100) Data 0000000000
C5 Current Pending Sector Count 100 (100) Data 0000000000
C6 Uncorrectable Sector Count 100 (100) Data 0000000000
C7 UltraDMA CRC Error Count 200 (253) Data 0000000000
Temperature 44 °C
Temperature Range ok (less than 50 °C)
Status Good
Partition 0
Partition ID Disk #0, Partition #0
Disk Letter C:
File System NTFS
Volume Serial Number D8460087
Size 56GB
Used Space 28.5GB (51%)
Free Space 27.4GB (49%)
Is there somewhere else I should look?
BTW, I'm using the portable version. If it IS in the installed version, can it be put in the portable version?
Had some free time to check further. Speccy sees the rpm on my Seagate 64-bit Win 7 pc, but doesn't see it on my Hitachi 32-bit Vista.
