I have .NET Framework 1.1 and 2.0 on my computer. Should I remove the older version? I don't know what I should do.
So do I.
Play it safe...keep them both.
See Andavari's answer in post 5 here to your other .NET question.
Hi again Icedrake,
More than anything you need to make a visit to MS Microsoft Update and use the "Custom" button.
It will show you everything that your system needs.
http://update.microsoft.com/microsoftupdat...t.aspx?ln=en-us
All system software is best left installed unless specifically instructed to do so by MS.
If you need a lot ,you can do it a little at a time but I normally don't.
Good luck,
davey
I Not keep NET Framework 1 & 1.1 fit NET 2 & take out old OK Harddisk 2 GB it ok to keep how big is the harddisk still you get NET 3 befor long.
now NET Frameworf 1.1 is back in auto up date,was not in P.C for one year, back on 25: April :2008
so if you take it out may come back?
This is a pretty good explanation of what you need and what you don't with .NET Framework.
Finding out about this stuff was a real pain in a**e, believe me. I bookmarked it in case it reared its ugly head again.
Hope it helps.
Hope it helps.
EDIT: If anyone sees me getting involved in any future .NET post. Shoot me.
Bang
Its almost as convoluted as Sun Java
Bang
Why the "bang" way over on the right.
I forgot all about that thread.IT was "excellent".
Dennis thanks for all the work you did on that thread.It cleared up a lot of confusion for me.
BANG
davey
I'm right handed so that's where the noise should come from.Why the "bang" way over on the right.
BANG
davey
Dennis did a great job.
