What the best way to view/monitor shell extensions?
I use ShellExView
ShellMenuView as well.
Do you need both of these -- or will one or the other do?
Neither will get everything. ShellMenuView handles static entries while ExView does COM objects. Depends what you want to do. I need both though.
