Security & Privacy Icon for Flash Blocker
I installed Ccleaner browser on two of our computers using the same exe file to install the software. One one installation, the Security & Privacy Center includes an icon for a Flash Blocker. See the attached image file. The other installation does not include this icon in the Security & Privacy Center. How do I add it?
Thanks for any advice.
Al
Are you sure, you are using the latest version on both computers?, If not than check versions of both browsers than update the older one.
