yes
Hey Novis1, I think I might finally have an answer for you. ![:)]()
-It's a FREE program called, "Revo Uninstaller". ( http://www.revouninstaller.com )
After you open up Revo Uninstaller, click on the "Tools" icon at the top. That will open up the "Optimization" box. At the bottom of Optimizations, click on "Tracks Cleaner". Now, click on the white down-arrow that's underneath "Evidence Remover". Finally, click on "Unrecoverable Delete".
Once you're in there, click the "Add files to be deleted" button. You can browse to find the file (in your case, the picture) that you want to delete, or if you know the location of the file, you can of course just enter that information. When you're done, just click "DELETE FOREVER", and that should take care of it.
If you don't know the location of the file(s), or if you want to wipe previously deleted data, you can use the Evidence Remover tool in Revo that I mentioned earlier. It's really easy to use, so I'll spare you the directions. WARNING: There is always the potential of deleting things that you want to keep with this sort of tool, SO USE WITH CAUTION.
-While I was writing this, something popped into my head. Maybe what you're seeing in Recuva is just the thumbnail of the picture that you want to delete, and NOT the actual picture itself. This might explain how Recuva is showing a picture that you have deleted. So, if the above steps don't help, you can try clearing Windows thumbnail cache in order to delete the file. Here's a site with the instructions:
http://www.wikihow.com/Clear-the-Thumbnail-Cache-in-Windows
I want to add a couple of things to their instructions though:
1) If you're using Windows XP, and you use Search, you'll need to check the box for "Search hidden files and folders" in the "More advanced options" drop-down menu. If you did everything right, you should find a lot of files named "Thumbs.db".
2) Instead of using "Select All" and "Delete" for removing the files, I would make a new folder on the Desktop, put all the files in the new folder, and then delete the folder using Revo's Unrecoverable Delete tool.
-Well... that's all for now. I REALLY hope this helps, and you can finally put your mind at ease. Good luck with everything! ![:)]()
