Tried it, said that it had completed...then tried PhotoRec...no joy, it didn't find any files! ![:(]()
Can you be a bit more specific?
Did you give the card a drive letter, and is it now being picked up OK by windows? Can you open it OK although it will only be a 30mb card?
If the creation of the partition went as it should, and your card can be opened as normal, albeit only 30mb, then the suggestion by Keatah has merit in that imaging software will now recognize it.
As well as the USB Image Tool, and RMPrepUSB, TestDisk can also create an Image of a memory card.
Whether it will just Image the 30mb or not is unknown until it's tried.
Successfully creating a back up Image opens up other possibilities. As long as the Image is created with for example the .img file extension, then that image can be mounted as a drive, which means it can be opened as a drive and explored.
You can also extract files from an Image with a free software like 7Zip.
help890, this all sounds good, but all these processes fail if a card or drive is damaged in a way which windows won't accept. They're all worth a try, but with your card, we have to accept that they are really long shots.
The other option, which has only been touched upon, is a professional company.
But we would never recommend someone go down that route, because we could be steering them into losing what could be, for an individual, a substantial sum of money. All we can ever do is point out that the option exists, at the same time making very clear that the end result could well be a very expensive negative one.
First of all confirm as to whether your card now has a drive letter, and can be accessed as normal, regardless of it's size. After that, we'll see what last throws of the dice we can try, and don't forget that absolutely anything your not sure about, or don't understand, no matter how daft you think your question might be, please ask. We're all ignorant of stuff until someone explains it to us.
